Problem after update to 1.8.6
mm
mmarquette #1
Internal Error
The server encountered an unexpected condition which prevented it from fulfilling the request.
and when i try
/usr/local/CyberCP/bin/python manage.py makemigrations
or
/usr/local/CyberCP/bin/python manage.py migrate
i got this error
[root@chamanweb CyberCP]# /usr/local/CyberCP/bin/python manage.py makemigrations
File “manage.py”, line 22, in
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/__ init__.py”, line 363, in execute_from_command_line
utility.execute()
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/__ init__.py”, line 355, in execute
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ba se.py”, line 283, in run_from_argv
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ba se.py”, line 327, in execute
self.check()
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ba se.py”, line 359, in check
include_deployment_checks=include_deployment_checks,
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ba se.py”, line 346, in run_checks
return checks.run_checks(**kwargs)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/checks/regist ry.py”, line 81, in run_checks
new_errors = check(app_configs=app_configs)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/checks/urls.p y”, line 16, in check_url_config
return check_resolver(resolver)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/checks/urls.p y”, line 26, in check_resolver
return check_method()
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/urls/resolvers.py” , line 254, in check
for pattern in self.url_patterns:
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/utils/functional.p y”, line 35, in get
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/urls/resolvers.py” , line 405, in url_patterns
patterns = getattr(self.urlconf_module, “urlpatterns”, self.urlconf_module)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/urls/resolvers.py” , line 398, in urlconf_module
return import_module(self.urlconf_name)
File “/usr/lib64/python2.7/importlib/init.py”, line 37, in import_module
import(name)
File “/usr/local/CyberCP/CyberCP/urls.py”, line 23, in
url(r’^websites/’,include(‘websiteFunctions.urls’)),
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/conf/urls/init .py”, line 50, in include
urlconf_module = import_module(urlconf_module)
import(name)
File “/usr/local/CyberCP/websiteFunctions/urls.py”, line 2, in
import views
File “/usr/local/CyberCP/websiteFunctions/views.py”, line 9, in
from plogical.website import WebsiteManager
File “/usr/local/CyberCP/plogical/website.py”, line 14, in
from virtualHostUtilities import virtualHostUtilities
File “/usr/local/CyberCP/plogical/virtualHostUtilities.py”, line 32, in
from CLManager.models import CLPackages
File “/usr/local/CyberCP/CLManager/models.py”, line 9, in
class CLPackages(models.Model):
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/models/base.py” , line 118, in new
“INSTALLED_APPS.” % (module, name)
RuntimeError: Model class CLManager.models.CLPackages doesn’t declare an explici t app_label and isn’t in an application in INSTALLED_APPS.
File "/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/
_ init__.py", line 363, in execute_from_command_line
utility.execute()
self.check()
import(name)
import(name)
import views
[root@chamanweb CyberCP]# /usr/local/CyberCP/bin/python manage.py migrate Traceback (most recent call last):
utility.execute()
self.check()
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/co mmands/migrate.py”, line 62, in run_checks
issues.extend(super(Command, self).run_checks(**kwargs))
import(name)
import(name)
import views
[root@chamanweb CyberCP]# /usr/local/CyberCP/bin/python manage.py makemigrations ^C
init
utility.execute()
self.check()
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/co mmands/migrate.py”, line 62, in _run_checks
issues.extend(super(Command, self)._run_checks(**kwargs))
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ba se.py”, line 346, in _run_checks
import(name)
import(name)
import views
le
letienvy #2
1.8.6 When I updated cyberpanel to version 1.8.6 it was also an error: when using filemanger, there was no “public_html” folder to upload the web source.
de
deltablue #3
Clean Install >> app installer does not work.
Cannot upload files via file manager.
Any idea why Every Cyberpanel comes with a lost of functions?
de
deltablue #4
Before I forget had this message no file or directory etc/opendkim/keys/ creating a website
Cy
CyberPanel #5
v1.8.6 had major changes on back end, we are fixing all the bugs as soon as someone reports them. Most of the bugs from last 2 days are patched. Try to upgrade now, if you still face any issues let us know.
mm
mmarquette #6
Hi @CyberPanel i did redo the upgrade but when i’m doing
i got this issue!
if you can fix that will be really appreciate thank you very much!
[root@chamanweb CyberCP]# /usr/local/CyberCP/bin/python manage.py migrate System check identified some issues:
WARNINGS:
?: (mysql.W002) MySQL Strict Mode is not set for database connection ‘default’
HINT: MySQL’s Strict Mode fixes many data integrity problems in MySQL, s uch as data truncation upon insertion, by escalating warnings into errors. It is strongly recommended you activate it. See: https://docs.djangoproject.com/en/1. 11/ref/databases/#mysql-sql-mode
?: (mysql.W002) MySQL Strict Mode is not set for database connection ‘rootdb’
Operations to perform:
Apply all migrations: CLManager, admin, auth, backup, baseTemplate, containeri zation, contenttypes, databases, dns, dockerManager, emailMarketing, emailPremiu m, firewall, ftp, loginSystem, mailServer, managePHP, manageServices, packages, s3Backups, sessions, websiteFunctions
Running migrations:
Applying CLManager.0001_initial…Traceback (most recent call last):
utility.execute()
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ba se.py”, line 330, in execute
output = self.handle(*args, **options)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/co mmands/migrate.py”, line 204, in handle
fake_initial=fake_initial,
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/migrations/exec utor.py”, line 115, in migrate
state = self._migrate_all_forwards(state, plan, full_plan, fake=fake, fake_i nitial=fake_initial)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/migrations/exec utor.py”, line 145, in migrate_all_forwards
state = self.apply_migration(state, migration, fake=fake, fake_initial=fake
initial)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/migrations/exec utor.py”, line 244, in apply_migration
state = migration.apply(state, schema_editor)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/migrations/migr ation.py”, line 129, in apply
operation.database_forwards(self.app_label, schema_editor, old_state, projec t_state)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/migrations/oper ations/models.py”, line 97, in database_forwards
schema_editor.create_model(model)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/backends/base/s chema.py”, line 302, in create_model
self.execute(sql, params or None)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/backends/base/s chema.py”, line 119, in execute
cursor.execute(sql, params)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/backends/utils. py”, line 65, in execute
return self.cursor.execute(sql, params)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/utils.py”, line 94, in exit
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/backends/utils. py”, line 63, in execute
return self.cursor.execute(sql)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/backends/mysql/ base.py”, line 101, in execute
return self.cursor.execute(query, args)
File “/usr/lib64/python2.7/site-packages/MySQLdb/cursors.py”, line 205, in exe cute
self.errorhandler(self, exc, value)
File “/usr/lib64/python2.7/site-packages/MySQLdb/connections.py”, line 36, in defaulterrorhandler
raise errorclass, errorvalue
django.db.utils.OperationalError: (1050, “Table ‘CLManager_clpackages’ already e xists”)
hu
humphump #7
Imgur
[04-56-58-Fri-Jul-2019] {“report_safe”:true,“required_hits”:“5”,“rewrite_header”:"Subject [SPAM] ",“required_score”:“5”}
[05-00-08-Fri-Jul-2019] {“report_safe”:true,“required_hits”:“5”,“rewrite_header”:"Subject [SPAM] ",“required_score”:“5”}
2019-07-12 23:43:53.998076 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [checkprivatecache 1]
2019-07-12 23:43:53.998094 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [checkpubliccache 1]
2019-07-12 23:43:53.998128 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [maxcacheobjsize 10000000]
2019-07-12 23:43:53.998147 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [maxstaleage 200]
2019-07-12 23:43:53.998163 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [qscache 1]
2019-07-12 23:43:53.998179 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [reqcookiecache 1]
2019-07-12 23:43:53.998210 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [respcookiecache 1]
2019-07-12 23:43:53.998226 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [ignorereqcachectrl 1]
2019-07-12 23:43:53.998240 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [ignorerespcachectrl 0]
2019-07-12 23:43:53.998254 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [enablecache 0]
2019-07-12 23:43:53.998268 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [expireinseconds 3600]
2019-07-12 23:43:53.998282 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [enableprivatecache 0]
2019-07-12 23:43:53.998296 [INFO] [PlainConf] [httpServerConfig:] module [cache] add param [privateexpireinseconds 3600]
2019-07-12 23:43:53.998324 [NOTICE] Loading LiteSpeed/1.4.48 Open (built: Fri Jun 21 18:20:27 UTC 2019) …
2019-07-12 23:43:54.021919 [NOTICE] Using [BoringSSL]
2019-07-12 23:43:54.054025 [NOTICE] [ADMIN] server socket: uds://usr/local/lsws/admin/tmp/admin.sock.7833
2019-07-12 23:43:54.054889 [NOTICE] chroot is disabled.
2019-07-12 23:43:54.054926 [INFO] old priority: 0, new priority: 0
2019-07-12 23:43:54.055014 [INFO] [config:server:basics2] For better obscurity, server version number is hidden in the response header.
2019-07-12 23:43:54.118758 [NOTICE] [PID: 1094]: forked cgid: 1111
2019-07-12 23:43:54.131468 [INFO] [PlainConf] [adminConfig:] start parsing file /usr/local/lsws/admin/conf/admin_config.conf
2019-07-12 23:43:54.178696 [INFO] [Module: modcompress 1.1] has been initialized successfully
2019-07-12 23:43:54.181957 [INFO] [Module: moddecompress 1.1] has been initialized successfully
2019-07-12 23:43:54.185634 [INFO] [Module: cache 1.61] has been initialized successfully
2019-07-12 23:43:54.212326 [NOTICE] The maximum number of file descriptor limit is set to 6000.
2019-07-12 23:43:54.242789 [INFO] [PlainConf] [virtualHostConfig:] start parsing file /usr/local/lsws/conf/vhosts/Example/vhconf.conf
2019-07-12 23:43:54.249996 [INFO] [PlainConf] [context:/] rewrite add rules [rewritefile .htaccess]
2019-07-12 23:43:54.253700 [INFO] [config:server:vhosts:vhost:Example] config context /.
2019-07-12 23:43:54.259947 [INFO] RewriteFile [.htaccess] parsed, return 0.
2019-07-12 23:43:54.259996 [INFO] [config:server:vhosts:vhost:Example] config context /blocked/.
2019-07-12 23:43:54.260040 [INFO] [config:server:vhosts:vhost:Example] config context /cgi-bin/.
2019-07-12 23:43:54.260147 [INFO] [config:server:vhosts:vhost:Example] config context /docs/.
2019-07-12 23:43:54.260220 [INFO] [config:server:vhosts:vhost:Example] config context /protected/.
2019-07-12 23:43:54.260253 [ERROR] [config:server:vhosts:vhost:Example:context:/protected/] Path for context location is invalid: /usr/local/lsws/Example/html/protected/
2019-07-12 23:43:54.261183 [INFO] [PlainConf] [virtualHostTemplate:] start parsing file /usr/local/lsws/conf/templates/ccl.conf
2019-07-12 23:43:54.262573 [INFO] [PlainConf] [context:/] rewrite add rules [rewritefile .htaccess]
2019-07-12 23:43:54.262638 [INFO] [PlainConf] [virtualHostTemplate:] start parsing file /usr/local/lsws/conf/templates/rails.conf
2019-07-12 23:43:54.265087 [INFO] [PlainConf] [context:/] rewrite add rules [rewritefile .htaccess]
2019-07-12 23:43:54.265158 [NOTICE] [ZConfManager] No VHosts added, do not send!
2019-07-12 23:43:54.266053 [NOTICE] [AutoRestarter] new child process with pid=1137 is forked!
2019-07-12 23:43:54.266338 [NOTICE] [AutoRestarter] new child process with pid=1138 is forked!
2019-07-12 23:43:54.276661 [NOTICE] [child: 1137] Successfully change current user to nobody
2019-07-12 23:43:54.276775 [NOTICE] Child: 1137] Core dump is enabled.
2019-07-12 23:43:54.276859 [NOTICE] [Child: 1137] Setup swapping space…
2019-07-12 23:43:54.278379 [NOTICE] [Child: 1137] LiteSpeed/1.4.48 Open starts successfully!
2019-07-12 23:43:54.297026 [INFO] Stop listener *:7080.
2019-07-12 23:43:54.301040 [NOTICE] [child: 1138] Successfully change current user to nobody
2019-07-12 23:43:54.301145 [NOTICE] Child: 1138] Core dump is enabled.
2019-07-12 23:43:54.301238 [NOTICE] [Child: 1138] Setup swapping space…
2019-07-12 23:43:54.315940 [NOTICE] [Child: 1138] LiteSpeed/1.4.48 Open starts successfully!
mm
mmarquette #8
i’m also not able to log in my email anymore it’s telling me ×Authentication failed to every email im trying to login
Hi
Hifihedgehog #9
Same here! I just upgraded and now email accounts are broke. I and the rest of my users cannot access any of our email accounts. I just created a ticket. Please fix this ASAP! Other issues I can deal with, but emails have to be working for us.
mm
mmarquette #10
me i have restore to a previous state but if im doing the upgrade again im feary that i’ll loose acces to my email… so can you fix that please @CyberPanel
Hi
Hifihedgehog #12
Examining this in phpMyAdmin, the issue is all email accounts are now encrypted in 1.8.6 but old email accounts migrated with MD5 (incorrect) while any future or new accounts are properly encrypted with CRYPT. From what I can tell, the fix for old accounts that were improperly migrated would be to decrypt them from MD5 and reencrypt to CRYPT.
re
rebnaque #13
Is it possible to reinstall the CP, without damaging the installed sites, since I got problems with the 1.8.6 update?
Cy
CyberPanel #14
@rebnaque
Contact our support, will fix that for your. Re-install of CyberPanel is not necessary.
de
deltablue #15
Confirm the fixes. CyberPanel is production ready again.
TO ALL MY FELLOW CYBERPANEL ADOPTERS. BACKUP, BACKUP, BACKUP before upgrading.
Would be great to have a repair option and a version repository.
Cheers
Cy
CyberPanel #17
@mmarquette
You have multiple posts, can you kindly mention which one you are still facing?
mm
mmarquette #18
the one with /usr/local/CyberCP/bin/python manage.py migrate
and the email one because when upgrading it’s making me not being able to log into any email
mm
mmarquette #19
so before retrying i want to know if im going to endup the same as 2 days ago and need to restore or it will be all good as habitually :slight_smile:
and by the way you are doing a fucking great and nice job keep going!
re
rebnaque #20
I already solved the problem, it was only to change the database data in “/usr/local/CyberCP/CyberCP/settings.py” and to update again, everything was fine, except rainloop, which gives me this error in the browser: " [202] Data folder permissions error [is_writable] "I went to cd / usr / local / lscp / cyberpanel and chown -R lscpd: lscpd rainloop, but nothing, remains the same
