Problem Deleting Child Domains After Upgrade
re
revint #1
Provider: upCloud
Virtualization Type: KVM,
System: Centos 7.5
Installation option:
OLS or Enterprise?
Enterprise
official
no
yes
Install LiteSpeed Memcached?
yes
Install Memcached?
no
yes
Install Redis?
yes
Problem:
After upgrading to 1.8.4 i can’t delete domains or subdomains. They create but show 403 errors when visiting the website or subdomain (the ones that were created before the upgrade are OK) and when trying to delete the deleted message shows but they do not delete. I have tried this on 3 servers (one with a different provider and the same issue occurs).
I’ve also tried to re-run the upgrade on a few occasions.
Any help would be great
Cy
CyberPanel #2
cd /usr/local/CyberCP
python manage.py makemigrations
python manage.py migrate
Can you run these successfully?
re
revint #3
Thanks. Apologies, in the meantime I went down the route of a fresh install (I only had one domain with some sub domains on there).
After doing this, I have a new problem which may or not be related.
New domain and subdomains create and delete OK from the panel. But, the files do not.
None of the subdomains work. The CyberPanel page shows but when it’s deleted it shows a 403 error.
Looking at the log files, it appears that despite having a subdomain, it looks only to the main domain for website.
The error log shows:
2019-06-10 18:16:41.136741 [INFO] Add #7 suffix handler [lsphp72]->[lsphp72].
2019-06-10 18:16:41.136744 [INFO] Associate [lsphp73] with PHP handler [lsphp73].
2019-06-10 18:16:41.136747 [INFO] Add #8 suffix handler [lsphp73]->[lsphp73].
2019-06-10 18:16:41.136750 [INFO] [config:server:php] Try CloudLinux PHP selector handlers
2019-06-10 18:16:41.136755 [INFO] Create PHP handler [phpsel] with PHP binary [/usr/local/bin/lsphp]
2019-06-10 18:16:41.136761 [INFO] Add #9 suffix handler [phpsel]->[phpsel].
2019-06-10 18:16:41.136785 [INFO] Default PHP handler is [lsphp5], path [/usr/local/lsws/fcgi-bin/lsphp5]
2019-06-10 18:16:41.136792 [INFO] Add #10 suffix handler [php]->[lsphp5].
2019-06-10 18:16:41.136795 [INFO] Add #11 suffix handler [php5]->[lsphp5].
2019-06-10 18:16:41.136798 [INFO] Add #12 suffix handler [php53]->[lsphp53].
2019-06-10 18:16:41.136805 [INFO] Add #13 suffix handler [php54]->[lsphp54].
2019-06-10 18:16:41.136808 [INFO] Add #14 suffix handler [php55]->[lsphp55].
2019-06-10 18:16:41.136810 [INFO] Add #15 suffix handler [php56]->[lsphp56].
2019-06-10 18:16:41.136813 [INFO] Add #16 suffix handler [php70]->[lsphp70].
2019-06-10 18:16:41.136815 [INFO] Add #17 suffix handler [php71]->[lsphp71].
2019-06-10 18:16:41.136818 [INFO] Add #18 suffix handler [php72]->[lsphp72].
2019-06-10 18:16:41.136820 [INFO] Add #19 suffix handler [php73]->[lsphp73].
2019-06-10 18:16:41.136870 [INFO] [/usr/local/lsws/conf/httpd.conf:12] try to add listener: ‘:80’.
2019-06-10 18:16:41.136883 [INFO] [/usr/local/lsws/conf/httpd.conf:13] try to add listener: ‘[::]:80’.
2019-06-10 18:16:41.136889 [INFO] [/usr/local/lsws/conf/httpd.conf:14] try to add listener: '
:443’.
2019-06-10 18:16:41.136895 [INFO] [/usr/local/lsws/conf/httpd.conf:15] try to add listener: ‘[::]:443’.
2019-06-10 18:16:41.137002 [INFO] Processing config file: /usr/local/lsws/conf/modsec.conf
2019-06-10 18:16:41.137034 [INFO] Processing config directory: /usr/local/lsws/conf
2019-06-10 18:16:41.137078 [ERROR] [/usr/local/lsws/conf/modsec.conf:19] Failed to get absolute path for [/usr/local/lsws/conf/rules.conf/(null)]!
2019-06-10 18:16:41.137089 [INFO] Processing config file: /usr/local/lsws/conf/vhosts/revolutionlearning.com/vhost.conf
2019-06-10 18:16:41.137120 [INFO] Processing config file: /usr/local/lsws/conf/vhosts/tools.revolutionlearning.com/vhost.conf
2019-06-10 18:16:41.146541 [ERROR] [/usr/local/lsws/conf/vhosts/tools.revolutionlearning.com/vhost.conf:29] Listener for default is not available!
2019-06-10 18:16:41.146611 [INFO] [UDP:10.2.6.147:80] initPacketsIn: allocated 100 packets
2019-06-10 18:16:41.146630 [INFO] [UDP:127.0.0.1:80] initPacketsIn: allocated 100 packets
2019-06-10 18:16:41.146646 [INFO] [UDP:94.237.50.15:80] initPacketsIn: allocated 100 packets
2019-06-10 18:16:41.146659 [INFO] [UDP:[::1]:80] initPacketsIn: allocated 100 packets
2019-06-10 18:16:41.146673 [INFO] [UDP:[2a04:3541:1000:500:1cc3:46ff:fe14:8c0]:80] initPacketsIn: allocated 100 packets
2019-06-10 18:16:41.146684 [INFO] [UDP:10.2.6.147:443] initPacketsIn: allocated 100 packets
2019-06-10 18:16:41.146695 [INFO] [UDP:127.0.0.1:443] initPacketsIn: allocated 100 packets
2019-06-10 18:16:41.146704 [INFO] [UDP:94.237.50.15:443] initPacketsIn: allocated 100 packets
2019-06-10 18:16:41.146716 [INFO] [UDP:[::1]:443] initPacketsIn: allocated 100 packets
2019-06-10 18:16:41.146726 [INFO] [UDP:[2a04:3541:1000:500:1cc3:46ff:fe14:8c0]:443] initPacketsIn: allocated 100 packets
[Mon Jun 10 18:16:41 2019] [notice] Finish reading Apache configuration, server configured – resuming normal operations
2019-06-10 18:16:41.146992 [NOTICE] litespeed (7723) is ready
2019-06-10 18:16:41.147239 [NOTICE] [AutoRestarter] new child process with pid=7726 is forked!
2019-06-10 18:16:41.149102 [NOTICE] [Child: 7726] Setup swapping space…
2019-06-10 18:16:41.149135 [NOTICE] [child: 7726] Successfully change current user to nobody
2019-06-10 18:16:41.149140 [NOTICE] [Child: 7726] Core dump is enabled.
2019-06-10 18:16:41.149225 [ALERT] [Child: 7726] LiteSpeed/5.3.5 Enterprise starts successfully!
Seemingly, there is a problem with VHOSTS Listener
Main log file shows
[06-10-38-Mon-Jun-2019] [Errno 2] No such file or directory: ‘/home/tools.revolutionlearning.com’ [Not able to remove virtual host directory from /home continuing…]
[06-11-46-Mon-Jun-2019] [Errno 17] File exists: '/home/revolutionlearning.com/public_html/tools.revolutionlearning.com’329 [Not able to create directories for virtual host [createDirectoryForDomain]]
Any ideas?
The sub-domain would be tools.maindomain.com
Cy
CyberPanel #4
Try to add index.php or index.html in document root of child-domain and see it still does not work ?
ys
ysintos #5
The website deletition is not working at all for me.
ro
roziqbahtiar #7
this happend to me too
i can’t delete website and sub-child
ro
roziqbahtiar #9
this is my main log
[08-47-42-Thu-Jun-2019] (1054, "Unknown column 'e_domains.childOwner_id' in 'field list'") [deleteDomain] [08-47-59-Thu-Jun-2019] (1054, "Unknown column 'e_domains.childOwner_id' in 'field list'") [deleteDomain] [08-48-20-Thu-Jun-2019] (1054, "Unknown column 'e_domains.childOwner_id' in 'field list'") [deleteDomain] [09-01-03-Thu-Jun-2019] (1054, "Unknown column 'e_domains.childOwner_id' in 'field list'") [deleteDomain] [09-01-09-Thu-Jun-2019] (1054, "Unknown column 'e_domains.childOwner_id' in 'field list'") [deleteDomain] [09-02-15-Thu-Jun-2019] (1054, "Unknown column 'e_domains.childOwner_id' in 'field list'") [deleteDomain] [09-07-14-Thu-Jun-2019] (1054, "Unknown column 'e_domains.childOwner_id' in 'field list'") [Not able to remove virtual host configuration from main configuration file.] [09-36-45-Thu-Jun-2019] (1054, "Unknown column 'e_domains.childOwner_id' in 'field list'") [deleteDomain]
