Extending existing volume and "Connect" docs
Cy
CyberPanel #2
If you want to play with /home better do it before creating any website and rest should be fine.
To connect the server to platform just enter the admin username and its password, then most of the functions are similar to CyberPanel itself.
mj
mjf777 #3
Thank you.
Will there be an issue if I copy all contents of /home (including existing websites) to another volume and map that as the /home folder?
Cy
CyberPanel #4
No problem at all.
mj
mjf777 #5
Thanks!
