Problem with .htaccess rules
ro
romain #1
It is about all the sites, the vhost are OK like this:
rewrite {
enable 1
autoLoadHtaccess 1
But the rules are not applied using htaccess.
A php file setting header rules works fine but not the htaccess rule equivalent.
ju
julianodls #3
Hello
I am also having same problems, autoLoadHtaccess does not work correctly, problems on all sites that have subfolders
qt
qtwrk #4
could you guys provide a more clearly example for us to check ?
ro
romain #5
Restart LSWS is always the good way to apply any change
