Smtp Problem
Sh
Shorty #1
hi i am having a problem can help you all the settings looks normal but tls can’t activate
ErrorException: Email to em*****@gmail.com failed: [E_WARNING] stream_socket_enable_crypto(): Peer certificate CN=host.cleared.com' did not match expected CN=cleared’
Sh
Shorty #2
Problem Solved
/etc/dovecot/dovecot.conf
Added
auth_mechanisms = plain login
Phpmailer
Changed Server IP to Server Host Name
$mail->Host = “hostname”;
w3
w3services #3
Warning: stream_socket_enable_crypto(): SSL operation failed with code 1. OpenSSL Error messages:
error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed in /home/XXXXXup.com/public_html/W3MAILBOX/YYYY/lib/class.smtp.php on line 368
Fatal error: Uncaught phpmailerException: SMTP Error: Could not connect to SMTP host. in /home/XXXXXup.com/public_html/W3MAILBOX/YYYY/lib/class.phpmailer.php:1678
Is anyone also facing the issue?
