Upgrade OLS and MariaDB?
ri
ricardofh #1
How to upgrade MariaDB and OpenLiteSpeed version? In OLS is currently using 1.4 and 1.5 has just been released, also, when I installed MariaDB it was with another version and there is a new one, “yum upgrade” does not do this.
qt
qtwrk #2
for OLS you can just yum update openlitespeed, source code is always prior to yum package so it may have some delay before yum package is out.
what mariadb version you installed ?
ri
ricardofh #3
for OLS you can just `yum update openlitespeed`, source code is always prior to yum package so it may have some delay before yum package is out.
That did not work, still running 1.4, I am running MariaDB 10 as it was the stable at the moment I installed CyberPanel
Any word on this @CyberPanel ?
Cy
CyberPanel #4
Keep the same MariaDB version for now. For OLS you can do
yum update
yum upgrade openlitespeed
