Closed how to change max_input_vars ?? Help
TH
THIAGO23 #1
how to change max_input_vars?
I am a new user and wanted to greatly alter max_input_vars
but I already changed in the php advenced and even then it does not apply in the sites how can it be solved ??
Help
Cy
CyberPanel #3
You need to check which version your site is using, also show us your phpinfo page.
Cy
CyberPanel #5
Please remove ; before max_input_vars
TH
THIAGO23 #6
I’ve tried to apply it several times and I’ve even created a php.ini php.user edit in the .htacess without result
Cy
CyberPanel #7
Did you remove ; ?
Am
Amir #8
removing ; and then restarted the server > loved
ch
charles #9
Thanks !! All afternoon searching for this ! Love u !
