Problem with CyberPanel
TQ
Tần Quảng #1
I encountered some problems with CyberPanel, specifically as follows:
  1. Firewall rule:
    https://i.imgur.com/MSTYt5l.png
    As in the picture, I proceeded to open the https firewall with port 443, but when I visited the https site, I got an error: “ERR_CONNECTION_REFUSED”.
  2. Problems with “Create a site”:
    This error I received when trying to create a web page (pointed to the DNS server), when I checked the “Additional features”
    :heavy_check_mark: SSL
    :heavy_check_mark: DKIM Support
    :heavy_check_mark: open_basedir Protection
    I received the error:
    “[Errno 2] No such file or directory: u ‘/home/cyberpanel/random_number’”.
    Click “Back” and press “Create site” again:
    “Error: 283 Failed to obtain SSL for domain. [issueSSLForDomain] [404]”.
  3. fileManager.php Not Found?!
    When I try to access File Manager, I get the error File Manager doesn’t load!
    https://preview.ibb.co/m8iCAe/111.png
    And in the Console window, I get the following information:
    “angular.js:12701 POST https://my_host_ip:8090/filemanager/domain/php/fileManager.php 404 (Not Found)”.
  4. Users can’t use “default” package!
    I do not want to create new service packages, I want everyone to use the “default” package, however, it looks like this package is only for admin. I tried the Reseller but didn’t see this package!
Are there any solutions to this problem? I have created a support ticket, but haven’t answered yet!
Cy
CyberPanel #2
You changed the name of listeners to HTTP and HTTPS, don’t make any custom changes in configuration files to already defined confs.
TQ
Tần Quảng #3
You changed the name of listeners to HTTP and HTTPS, don't make any custom changes in configuration files to already defined confs.
  • When I try to access File Manager, I get the error File Manager doesn’t load!
  • I do not want to create new service packages, I want everyone to use the “default” package, however, it looks like this package is only for admin. I tried the Reseller but didn’t see this package!
  • https://i.imgur.com/MSTYt5l.png
TQ
Tần Quảng #5
Did you read? https://forums.cyberpanel.net/discussion/171/some-donts-after-installing-cyberpanel (This specifically applies to OpenLiteSpeed)
I have read and I just changed the MySQL password, everything else remains the sam
Cy
CyberPanel #6
how do your rewrite rules look like?
TQ
Tần Quảng #7
There are no changes! Everything is the original!
Cy
CyberPanel #8
For you I recommend a fresh install, add your domain and don’t modify anything. Normally you can make additions to your configurations file, but modifications to existing configurations are not recommended.
Before I further look into this, need to make sure everything is default. (As earlier I noticed you made some changes to main conf file through webadmin or directly)
TQ
Tần Quảng #9
Okay, I’ll reinstall it!
