SSL/HTTPS issue after 1.7.3 upgrade and clean install.
am
amazy #1
Hello All. Does anybody has problem with ssl/https since last 1.7.3 update?
I have made no changes to vhost or rewrite rules.
To sum up:
    1. I have done twice a fresh clean install of last CP version 1 db with opelitespeed 1.4.40
      -2) Created a wordpress site with one click LSCache support with ssl option checked. On the fresh install, ssl wasn’t working - no secure connection. No error message displayed.
      -3) Reinstalled SSL cert with CP ----> Manage SSL . Same issue, no error message displayed after SSL creation
      -4) Checked my vhost path for cert, all seems good, cert seems generated, but still under http, no secure connection.
      Private Key File /etc/letsencrypt/live/domain.com/privkey.pem
      Certificate File /etc/letsencrypt/live/domain.com/fullchain.pem
      -5) Restarted: systemctl restart lsws Same issue.
      -6) I also noticed a random issue with File Manager file explorer freezing (blue spiner) unable to explore website files issue since last version.
      -7) Browser error message:
      The certificate is not trusted because it is self-signed. HTTP Strict Transport Security: false HTTP Public Key Pinning: false
Cy
CyberPanel #2
are you on aws?
am
amazy #3
Hi Usman. No I’m on Vultr.
Never had any of these issue on the same server with CP 1.7.1
jd
jdiggity81 #4
Same problem i am having. If you tried 3 times to get it to work wait 3 days then retry. might be the rate limiting of lets encrypt
am
amazy #5
HI @usmannasir
When check CP main log file about SSL issue I have this output after 3 clean 1.7.3 install on the same server as before:
[01-43-30-Tue-Nov-2018] Failed to obtain SSL, issuing self-signed SSL for: mydomain.com
[01-43-30-Tue-Nov-2018] Self signed SSL issued for mydomain.com.
[01-50-24-Tue-Nov-2018] Trying to obtain SSL for: mydomain.com and: www.mydomain.com
[01-50-26-Tue-Nov-2018] Failed to obtain SSL for: mydomain.com and: www.mydomain.com
[01-50-26-Tue-Nov-2018] Trying to obtain SSL for: mydomain.com
[01-50-27-Tue-Nov-2018] Failed to obtain SSL, issuing self-signed SSL for: mydomain.com
[01-50-27-Tue-Nov-2018] Self signed SSL issued for mydomain.com.
[11-02-50-Wed-Nov-2018] Trying to obtain SSL for: mydomain.com and: www.mydomain.com
[11-02-52-Wed-Nov-2018] Failed to obtain SSL for: mydomain.com and: www.mydomain.com
[11-02-52-Wed-Nov-2018] Trying to obtain SSL for: mydomain.com
[11-02-54-Wed-Nov-2018] Failed to obtain SSL, issuing self-signed SSL for: mydomain.com
[11-02-54-Wed-Nov-2018] Self signed SSL issued for mydomain.com.
am
amazy #6
as stated before the certs are added in vhost conf correctly. It’s just the SSL generation that is not working.
Using certbot instead is not a problem for me but using cyberpanel is more convenient for my clients.
Thank you.
am
amazy #7
@jdiggity81 Maybe it could be an issue on let’s encrypt side because of too much SSL cert generation but I have this issue from 1st time try so i don’t think it’s the issue here
jd
jdiggity81 #8
I am able to issue new certs to subdomains. but the main domain has an issue. I think there is a problem in the reissue of domains right now with this software. This is the same issue i am getting amazy.
