Problem with Domain & CloudFlare
KH
KHR #1
I have installed CyberPanel on Amazon Lightsail (4 GB RAM, 2 vCPUs). All the necessary ports are open from Amazon and CyberPanel. I have installed WP. I using CloudFlare DNS, but I can’t access to site using Domain.
When I setup DNS and CDN on CloudFlare site is not accessible but returning to Error 502 (Bad gateway). Firewall Screenshots: https://i.imgur.com/AHJSDXh.jpg
Now what is the Problem? How to fix it?
qt
qtwrk #2
is it accessible without CF proxy ?
KH
KHR #3
Some times.
KH
KHR #4
I figured out the Problem, It’s SSL issue, when I enabled Full SSL on CloudFlare, It’s returning to 502 Error page, because SSL is not installed on Origin Sever.
But I installed SSL using CyberPanel, I also reissued few times for fixing the Issue. That means CyberPanel actually not installing SSL but showing the Success message. It’s a bugs of CyberPanel that it’s showing success message without installing SSL.
How can I fix this Issue?
us
usmannasir #5
I figured out the Problem, It's SSL issue, when I enabled Full SSL on CloudFlare, It's returning to 502 Error page, because SSL is not installed on Origin Sever.
What does CyberPanel main log file says when you try to issue SSL?
