Hi, i have this error? have any idea?
the web panel does not open. It’s a 503 error. I’ve reinstalled it many times.
Eyl 20 15:25:49 server.fazli.com systemd[1]: Started gunicorn daemon.
– Subject: Unit gunicorn.service has finished start-up
– Defined-By: systemd
– Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
– Unit gunicorn.service has finished starting up.
– The start-up result is done.
Eyl 20 15:25:49 server.fazli.com systemd[1]: Starting gunicorn daemon…
– Subject: Unit gunicorn.service has begun start-up
– Unit gunicorn.service has begun starting up.
Eyl 20 15:25:49 server.fazli.com systemd[18440]: Failed at step EXEC spawning /usr/local/CyberCP/bin/gunicorn: No such file or directory
– Subject: Process /usr/local/CyberCP/bin/gunicorn could not be executed
– The process /usr/local/CyberCP/bin/gunicorn could not be executed and failed.
– The error number returned by this process is 2.
Eyl 20 15:25:49 server.fazli.com systemd[1]: gunicorn.service: main process exited, code=exited, status=203/EXEC
Eyl 20 15:25:49 server.fazli.com kill[18442]: Usage:
Eyl 20 15:25:49 server.fazli.com kill[18442]: kill [options] <pid|name> […]
Eyl 20 15:25:49 server.fazli.com kill[18442]: Options:
Eyl 20 15:25:49 server.fazli.com kill[18442]: -a, --all do not restrict the name-to-pid conversion to processes
Eyl 20 15:25:49 server.fazli.com kill[18442]: with the same uid as the present process
Eyl 20 15:25:49 server.fazli.com kill[18442]: -s, --signal send specified signal
Eyl 20 15:25:49 server.fazli.com kill[18442]: -q, --queue use sigqueue(2) rather than kill(2)
Eyl 20 15:25:49 server.fazli.com kill[18442]: -p, --pid print pids without signaling them
Eyl 20 15:25:49 server.fazli.com kill[18442]: -l, --list [=] list signal names, or convert one to a name
Eyl 20 15:25:49 server.fazli.com kill[18442]: -L, --table list signal names and numbers
Eyl 20 15:25:49 server.fazli.com kill[18442]: -h, --help display this help and exit
Eyl 20 15:25:49 server.fazli.com kill[18442]: -V, --version output version information and exit
Eyl 20 15:25:49 server.fazli.com kill[18442]: For more details see kill(1).
Eyl 20 15:25:49 server.fazli.com systemd[1]: gunicorn.service: control process exited, code=exited status=1
Eyl 20 15:25:49 server.fazli.com systemd[1]: Unit gunicorn.service entered failed state.
Eyl 20 15:25:49 server.fazli.com systemd[1]: gunicorn.service failed.
Eyl 20 15:25:49 server.fazli.com systemd[18447]: Failed at step EXEC spawning /usr/local/CyberCP/bin/gunicorn: No such file or directory
Eyl 20 15:25:49 server.fazli.com kill[18449]: Usage:
Eyl 20 15:25:49 server.fazli.com kill[18449]: kill [options] <pid|name> […]
Eyl 20 15:25:49 server.fazli.com kill[18449]: Options:
Eyl 20 15:25:49 server.fazli.com kill[18449]: -a, --all do not restrict the name-to-pid conversion to processes
Eyl 20 15:25:49 server.fazli.com kill[18449]: with the same uid as the present process
Eyl 20 15:25:49 server.fazli.com kill[18449]: -s, --signal send specified signal
Eyl 20 15:25:49 server.fazli.com kill[18449]: -q, --queue use sigqueue(2) rather than kill(2)
Eyl 20 15:25:49 server.fazli.com kill[18449]: -p, --pid print pids without signaling them
Eyl 20 15:25:49 server.fazli.com kill[18449]: -l, --list [=] list signal names, or convert one to a name
Eyl 20 15:25:49 server.fazli.com kill[18449]: -L, --table list signal names and numbers
Eyl 20 15:25:49 server.fazli.com kill[18449]: -h, --help display this help and exit
Eyl 20 15:25:49 server.fazli.com kill[18449]: -V, --version output version information and exit
Eyl 20 15:25:49 server.fazli.com kill[18449]: For more details see kill(1).
Eyl 20 15:25:49 server.fazli.com systemd[18454]: Failed at step EXEC spawning /usr/local/CyberCP/bin/gunicorn: No such file or directory
