Amozon ec2 Centos install problem
gu
gulo #1
Hi, i have this error? have any idea?
[centos@ip-172-31-41-151 ~]$ sh <(curl https://cyberpanel.net/install.sh || wget -O - https://cyberpanel.net/install.sh)
100 9071 100 9071 0 0 19230 0 --:–:-- --:–:-- --:–:-- 19259
Superuser privileges are required to run this script.
e.g. “sudo /dev/fd/63”
[centos@ip-172-31-41-151 ~]$ sudo sh <(curl https://cyberpanel.net/install.sh || wget -O - https://cyberpanel.net/install.sh)
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0sh: /dev/fd/63: Böyle bir dosya ya da dizin yok
100 9071 100 9071 0 0 18020 0 --:–:-- --:–:-- --:–:-- 17998
curl: (23) Failed writing body (0 != 9071)
–2018-09-19 08:09:04-- https://cyberpanel.net/install.sh
cyberpanel.net (cyberpanel.net) çözümleniyor… 35.236.113.106
cyberpanel.net (cyberpanel.net)[35.236.113.106]:443 bağlanılıyor… bağlantı kuruldu.
HTTP isteği gönderildi, yanıt bekleniyor… 200 OK
Uzunluk: 9071 (8,9K) [application/x-sh]
Saving to: ‘STDOUT’
0% [ ] 0 --.-K/s in 0s
Cannot write to ‘-’ (Başarılı).
Cy
CyberPanel #2
Run
sudo su
Then continue with isntallation.
gu
gulo #3
thanks a lot
gu
gulo #4
i have this errors::
[root@ip-172-31-40-196 centos]# systemctl status gunicorn.socket
● gunicorn.socket - gunicorn socket
Loaded: loaded (/etc/systemd/system/gunicorn.socket; enabled; vendor preset: disabled)
Active: failed (Result: resources)
Listen: 127.0.0.1:5003 (Stream)
Eyl 19 08:54:30 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: Starting gunicorn socket.
Eyl 19 09:06:01 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: gunicorn.socket failed to lis…y
Eyl 19 09:06:01 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: Failed to listen on gunicorn …
Eyl 19 09:06:01 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: Starting gunicorn socket.
Eyl 19 09:07:05 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: gunicorn.socket failed to lis…y
Eyl 19 09:07:05 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: Failed to listen on gunicorn …
Eyl 19 09:07:05 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: Starting gunicorn socket.
Eyl 19 09:09:27 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: gunicorn.socket failed to lis…y
Eyl 19 09:09:27 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: Failed to listen on gunicorn …
Eyl 19 09:09:27 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: Starting gunicorn socket.
Hint: Some lines were ellipsized, use -l to show in full.
and
[root@ip-172-31-40-196 centos]# systemctl start gunicorn.socket
Job for gunicorn.socket failed. See “systemctl status gunicorn.socket” and “journalctl -xe” for details.
and
[root@ip-172-31-40-196 centos]# journalctl -xe
– The result is failed.
– Subject: Unit gunicorn.socket has begun start-up
– Defined-By: systemd
– Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
– Unit gunicorn.socket has begun starting up.
Eyl 19 09:09:27 ip-172-31-40-196.us-east-2.compute.internal polkitd[28085]: Unregistered Authentication A
Eyl 19 09:11:34 ip-172-31-40-196.us-east-2.compute.internal polkitd[28085]: Registered Authentication Age
Eyl 19 09:11:34 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: gunicorn.socket failed to listen
Eyl 19 09:11:34 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: Failed to listen on gunicorn sock
– Subject: Unit gunicorn.socket has failed
– Unit gunicorn.socket has failed.
Eyl 19 09:11:34 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: Starting gunicorn socket.
Eyl 19 09:11:34 ip-172-31-40-196.us-east-2.compute.internal polkitd[28085]: Unregistered Authentication A
lines 1319-1343/1343 (END)
Eyl 19 09:09:27 ip-172-31-40-196.us-east-2.compute.internal polkitd[28085]: Unregistered Authentication Agent for unix-process:29328:240008 (syst
Eyl 19 09:11:34 ip-172-31-40-196.us-east-2.compute.internal polkitd[28085]: Registered Authentication Agent for unix-process:29335:252800 (system
Eyl 19 09:11:34 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: gunicorn.socket failed to listen on sockets: No such file or directory
Eyl 19 09:11:34 ip-172-31-40-196.us-east-2.compute.internal systemd[1]: Failed to listen on gunicorn socket.
Eyl 19 09:11:34 ip-172-31-40-196.us-east-2.compute.internal polkitd[28085]: Unregistered Authentication Agent for unix-process:29335:252800 (syst
