pdns (power dns) and bind
am
ameerjaiswal #1
hello all - need some collective advice. I started a new job at the beginning of the summer and inherited someone else’s infrastructure and admin setup. Luckily it is pretty good overall.
In short I am trying to evaluate - is it worth learning to use a pdns setup or should I setup a BIND server?
I am a ‘sole-sysadmin’ so have some leeway. For the internal DNS (the private 10.0.0.0/8 subnets) my predecessor installed pdns with a sqllite backend.
It runs ok. I have familiarized myself with how to add / remove records; list the domain records, etc. Beyond that I am less than thrilled. The only documentation I have found is the doc.powerdns.com and it is reasonably well written…
I have roughly 300 servers in a handful of managed hosting datacenters. Based upon similar experience I am confident that bind servers could handle this and I am more familiar with Bind with a zone file as a backend.
I feel like power dns is a beast which can scale up to big domians with thousands of A records , etc. For my purposes, even if my number of servers triple - I will have a zone file of about 1000 lines… No big deal.
I suspect my predecessor wanted to learn pdns and set it up. I have different needs - we do not have any kind of AD/ LDAP setup. I want to get DNS/ LDAP and some kind of herd management like consul in place. And as a next step maybe kerberos. (ie something resembling the RHEL Identity server setup or the fedora freeIPA ).
I could replace the existing setup with BIND and a backend of zone files served out of git in a day.
Are there compelling reasons to stay with power DNS?
am
ameerjaiswal #2
any reply guys?
Za
Zafer #3
:rage: I’m stuck in rdns too, yahoo mails are not going, if I find a solution, I will share it here.
Friends who are still in the research phase, you do not need to try with bind. Since powerdns uses port 53, bind - powerdns conflicts and reserve dns does not work. :joy:
