What is this settings "Max Connections" for?
Ro
RoldanLT #1
PHP TUNING > PHP 7 > Max Connections ?
Is this the same as nginx limit_conn ?
Ro
RoldanLT #2
And what is this settings also?
LITESPEED TUNING > Max Connections & Max SSL Connections ?
Ro
RoldanLT #3
How can I set similar feature of limit_conn feature on Nginx?
I want to limit PHP process only if possible and not static files.
qt
qtwrk #4
I don’t know about the nginx thingy , but basically , this controls how many PHP processes can be running at same time.
for example if it’s 10 as default , then it means it will maxium run 10 LSPHP process , the 11th request wait be waiting in queue.
for you second question.
Ro
RoldanLT #5
Are those screenshots coming from CyberPanel? How can I access it?
Thanks!
Ro
RoldanLT #8
![](upload://kFO1hwgfkHxqaNhHN4DGinrwXeA.jpeg)
So I can limit maximum PHP process per domain?
domain1.com, I can set limit of 10.
domain2.com I can limit maximum of 2 process only.
That is correct?
Ro
RoldanLT #9
With OLS is it possible to limit max connection per IP?
limit_conn for Nginx.
Ro
RoldanLT #10
Seen it on OLS Panel, I hope we can define this on CyberPanel.
Very great to combat Layer 7 DOS attacks.
