Run multiple Python versions on system
du
duy13 #1
When using CyberPanel on Google Cloud VPS, I have encountered some Python errors:
I believe the reason is that Google Cloud VPS has automatically installed python-urllib3, python-requests … (generally, interfering with the “python” of the system out of our control)
That made CyberPanel unable to login:
ImportError: can not import name UnrewindableBodyError
I think you should create a new python version for your CyberPanel system to use, (in another location) it will not depend on the python available on the Centos 7 system (python 2.7.5 is too old). Install a newer version of Python like 3.6.5 or 2.7.15, which can be referenced here:
us
usmannasir #2
Centos 7. ?
du
duy13 #3
Centos 7. ?
Yes, Centos 7.(4-5) - Python 2.7.5
du
duy13 #4
So, is that feasible or problematic? :slight_smile:
When the system’s python crashes, the Cyberpanel can still run if it has a separate python program, you can proactively upgrade this seperate python or configure it to use resources more appropriately.
Sometimes upgrading to a newer version of Cyberpanel, you can get in trouble at step:
cd /usr/local/CyberCP
python manage.py makemigrations
python manage.py migrate
I believe using a separate Python will fix that
us
usmannasir #5
So GCP python version is upgraded to 3.x? I noticed that DO also remove Centos 7.4 with 7.5 and it still uses Python 2.7.
kh
khamiss #6
I am getting same issue once I do cantos YUM update ! , I think need to give an instruction for the solution to avoid such situation
us
usmannasir #7
pip uninstall requests
pip uninstall urllib3
yum remove python-urllib3
yum remove python-requests
yum install python-urllib3
yum install python-requests
This should solve your issue, I notice that GCP have not updated python version, just some libraries.
kh
khamiss #8
still not accessible how to force cyberpanel using ver 3 ?
where to change the paths ?
Django Version: 1.11.13
Exception Type: ImportError
Exception Value:
No module named ‘requests.packages.urllib3’
Exception Location: /usr/lib/python2.7/site-packages/requests/packages/init.py in load_module, line 95
Python Executable: /usr/bin/python
Python Version: 2.7.5
Python Path:
[’/usr/local/CyberCP’,
‘/usr/bin’,
‘/usr/lib/python2.7/site-packages/gunicorn-19.8.1-py2.7.egg’,
‘/usr/lib64/python27.zip’,
‘/usr/lib64/python2.7’,
‘/usr/lib64/python2.7/plat-linux2’,
‘/usr/lib64/python2.7/lib-tk’,
‘/usr/lib64/python2.7/lib-old’,
‘/usr/lib64/python2.7/lib-dynload’,
‘/usr/lib64/python2.7/site-packages’,
‘/usr/lib/python2.7/site-packages’]
us
usmannasir #9
Submit a ticket, will have a look.
