Problems with email
Ph
Philipinho #1
When i try to send a mail with rainloop i get this error “Cant connect to server” (other mail clients works).
Emails sent to me are also not received also.
If i want to create a new mail, my domain does not appear on the dropdown.
Ph
Philipinho #2
Issue 1 and 2 solved. I used sudo service postfix restart
Remaining 3: If i want to create a new mail, my domain does not appear on the dropdown.
le
leoasb #4
Were they able to solve the problem? If so, can they say how?
I’m facing the same problem. I have already reviewed the cloud configuration and everything is fine. Even so, I am not able to send internal or outgoing emails.
When I go in managepostfix I get the following message:
See CyberCP main log file.
I looked at the log and saw no error related to postfix.
Can you guide me on how to solve this problem?
PS: there is no blocking for sending e-mail, on the part of the provider, I have another server there also with the cyberpanel and everything works wonderfully well.
Cy
CyberPanel #5
@leoasb
Did you turn on email policy server?
le
leoasb #6
Yes, I have the email policy server and spam assasin enabled.
le
leoasb #7
Hmm … I did a test by turning off the service and sending the email was done: p
Does this mean that I can not use the upload limiter? we had problems with sending spam and wanted to limit uploading on account.
If you can help me.
