CSS problem with page sidebar
na
natalie #1
Hai,
I just install CyberPanel on cloud. The problem is when I first login everything is fine. But once I go to SSL > Hostname SSL and issue SSL certificate to a domain that I want to login using SSL, suddenly the page sidebar move to center.
If I use google developer tool I can move the sidebar back to the original place when I add “position: absolute”. But it dont work on firefox developer tool.
Login using the domain name also dont fix the problem.
Is anyone else facing the same issue.
Thank you.
Ho
Hope #2
In your user profile section shorten the name (First Name and Last Name).
See if this fixes your problem.
na
natalie #3
Hai Hope,
Wow, yes this fix it. Thank you Hope. you’re my hero.
But there is a lot thing I have to play to test this cp. Look great.
Thanks again Hope.
us
usmannasir #4
Let us know your bugs :slight_smile:
na
natalie #5
Yes, I will, just know about this cp yesterday. Try install it on arubacloud.
