Packages on CyberPanel help you assign resources to an individual website, you must create at least one package before you start creating websites. (Upon installation a default package is created)
Create Package
You can fill in all these resources according to your requirements, an example input can be:
Disk Space: 100
Bandwidth: 5000
FTP Accounts: 10
Database: 10
Emails: 5
Note: 0 is considered unlimited.
Modify Package
If you feel the need to modify the parameters for existing package you can do so via modify package page.
From the list select the package you want to modify and it will fetch the current parameters for the package, once you are satisfied with new parameters you can click “Modify Package”.
Delete Package
Delete the packages you won’t need any more.
