KVM
CentOS 7.6.1810
OLS
Back Up → Schedule Back Up → Select Destination (Remote Server IP) → Select Frequency (Daily) → Add Destination
Error Msg:
Cannot Add Schedule. Error message: ‘localPath’
Upon refresh, the remote IP shows in the list of scheduled backup, but it doesnt work.
Sorry my bad.
System wide python started having some module issue. I fixed that and the localpath issue
committed 07:27AM - 26 Aug 19 UTC
Pushed the fix as part of v1.9.0. You can upgrade.
Thanks. Able to add schedule now. Will check if backup work
Scheduled remote backups working. Thanks.
@CyberPanel now Remote Backup (Remote Transfer) dont work. Both 1.9.0
I will check that now @cybertech
rick
August 27, 2019, 9:03am
7
I have a local Scheduled backup on version1.9.0
I keep getting for all sites…
cat: /home/privateurl.com/backup/backupFileName: No such file or directory
I doubled checked the path and /home/privateurl.com/backup/ looks like a valid path.
If I run a manual local backup it completes!
I can see the backup in the patch…
“/home/privateurl.com/backup/”
@cybertech
Fixed → bug fix: remote transfer · usmannasir/cyberpanel@b248133 · GitHub
Will push later.
@rick
You can ignore this, local backups should be working fine.
@cyberpanel has it been pushed? not working yet.
rick
August 29, 2019, 7:29pm
11
upload image
cat: /home/test123.com/backup/backupFileName: No such file or directory
SCHEDULED backup still failing.
rick
August 29, 2019, 8:06pm
12
I am running Latest Version 1.9
Remote backups work now ONLY IF both panels are 1.9.0.
Scheduled backup will report back again soon.
@cybertech
Let me know if something is not working, I was busy fixing some issues in Email Policy Server, can check if you report any issues with backups.
@CyberPanel said:
@cybertech
Remote transfers between 1.9.0 panels work , first scheduled backup was successful. Will continue to monitor. Thank you.
pxnji
September 1, 2019, 7:09am
16
I got some issues here,
as you can see on picture, the information of created backup from schedule backup was doubled. And if i choose domain name from dropdown menu on Select Website, its automatically shows that it creating a backup but its shows like in the picture so long
rick
September 2, 2019, 7:04am
17
My scheduled backups never run? I have no scheduled backups. On Demand backups still work great… also whats with the file name? backup-somedomain-08-34-53-Tue-Aug-2019 todays date is 9-2-2019 whats 08-34-53? The server date and time is correct.
@pxnji
I think you can create ticket.
@rick
You can upgrade and re-setup schedule backups.
@CyberPanel cannot restore from a scheduled backup file (tar.gz) that is sent to remote backup panel. Both are 1.9.0.
File does not seem OK, need to check.
